Sweet Home 3D 7.2
This topic has been viewed 440495 times and has 90 replies
snmavronis
Country: USA
Re: Sweet Home 3D 7.2
Post by snmavronis »
P.S. Wish I could edit my posts.
Maybe it would be better if I uninstall Sweet Home 3D. Reinstall it under it's normal default paths which should create the eTeks\Sweet Home 3D folders and install all the SH3D plugins to start over. My other data folders should be accessible. I feel it's had a short circuit maybe registry settings are borked. What to you think?
Installing the program again won’t change anything.
Pleeeaaase, run the program from a cmd window like I proposed.
sjb007
Post by sjb007 »
@snmavronis Daniels gave you an incorrect path to find the log.txt file. This is strange as he wrote that little plugin [:))]
C:\Users\<your username>\AppData\Roaming\eTeks\Sweet Home 3D\log.txt
AppData is hidden by default in windows file explorer, so you may need to set explorer to show hidden files if you can't see it.
Or just run the command like Emmanuel asked. Either one should give us more info.
snmavronis
Country: USA
C:\Windows\System32>"D:\Program Files (x86)\Sweet Home 3D\SweetHome3D.exe" 2>"C:\Users\snmav\Desktop\log.txt"
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/D:/Program%20Files%20(x86)/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
snmavronis
Country: USA
Here's the hidden AppData log.txt file:
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262)
at java.desktop/javax.swing.AbstractButton.doClick(AbstractButton.java:369)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1020)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1064)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:297)
at java.desktop/java.awt.Component.processMouseEvent(Component.java:6635)
at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342)
at java.desktop/java.awt.Component.processEvent(Component.java:6400)
at java.desktop/java.awt.Container.processEvent(Container.java:2263)
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
... 40 more
Caused by: java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.base/java.util.ComparableTimSort.mergeHi(ComparableTimSort.java:870)
at java.base/java.util.ComparableTimSort.mergeAt(ComparableTimSort.java:487)
at java.base/java.util.ComparableTimSort.mergeForceCollapse(ComparableTimSort.java:426)
at java.base/java.util.ComparableTimSort.sort(ComparableTimSort.java:222)
at java.base/java.util.Arrays.sort(Arrays.java:1249)
at java.desktop/sun.awt.shell.Win32ShellFolderManager2.get(Win32ShellFolderManager2.java:313)
at java.desktop/sun.awt.shell.ShellFolder.get(ShellFolder.java:259)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$DirectoryComboBoxModel.addItem(WindowsFileChooserUI.java:1087)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI.doDirectoryChanged(WindowsFileChooserUI.java:741)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$11.propertyChange(WindowsFileChooserUI.java:832)
at java.desktop/java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:341)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:333)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:266)
at java.desktop/java.awt.Component.firePropertyChange(Component.java:8731)
at java.desktop/javax.swing.JFileChooser.setCurrentDirectory(JFileChooser.java:608)
at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:362)
at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:308)
at com.eteks.sweethome3d.swing.FileContentManager.showFileChooser(Unknown Source)
at com.eteks.sweethome3d.swing.FileContentManager.showSaveDialog(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.showSaveDialog(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.saveAs(Unknown Source)
... 44 more
... 40 more
... 44 more
Daniels118
Country: Italy
Post by Daniels118 »
@sbj007
My plugin uses the same method used by SH3D to get the output folder, it is the result of a computation, so it may vary depending on the environment.
@snmavronis
Btw, the plugin and the output redirection method from the command line are mutually exclusive, so only one should be used.
@snmavronis, @PUYBARET
The specific problem it is described here:
https://bugs.openjdk.org/browse/JDK-8305072
and a possible workaround that may be applied without waiting for a bug fix is here (but I'm not able to test it):
https://github.com/apache/netbeans/discussions/6361
It would be nice to see which files are actually breking the file dialog.
Thanks Steve, that's the information I was looking for. You may not understand a word of it, but for Java programmers, it contains the information that will help them to fix your issue.
I'm pretty sure you actually encountered the bug #8305072 in Java mentioned by Daniele, which is not fixed yet.
Reading the comments of that bug report, it seems to be an issue bound to homonyms in the file system. Very strange, since a file name is supposed to be unique in a directory, but that could be half true from a user's point of view when localization is involved.
Could you check in the folder where you expect to save your files if there are some homonyms or files named with unconventional names?
snmavronis
Country: USA
I appreciate you guys spending time of this. I can't find any files with the same name within a folder. Sub-folders shouldn't matter but Windows won't allow that anyway, it would ask to overwrite or rename. In my home save folder I tried renaming some files that were home remodeling quotes containing # and ( ) and , symbols even though they are legal filename characters. Then I moved all unnecessary files into sub-folders. I also deleted some models in my home; computer equipment that was on a desk and a regular save. No change, can't do a save-as, no error on-screen it just ignores the menu selection. Here is a current directory list:
C:\Users\snmav\Pictures\House Plans>dir
Volume in drive C is Windows
Volume Serial Number is 2E85-8F3A
Directory of C:\Users\snmav\Pictures\House Plans
02/24/2024 11:00 AM <DIR> .
11/23/2023 04:15 PM <DIR> ..
02/24/2024 10:49 AM 195,217,656 3200future156.sh3d
11/03/2022 04:45 PM 259,695,828 3200SH3Dfuture144.sh3d
02/25/2023 06:20 PM 259,698,668 3200SH3Dfuture145.sh3d
03/31/2023 09:47 PM 259,698,674 3200SH3Dfuture146.sh3d
06/24/2023 09:50 PM 270,073,104 3200SH3Dfuture147.sh3d
07/11/2023 11:00 AM 272,234,491 3200SH3Dfuture148.sh3d
07/23/2023 05:27 PM 289,812,997 3200SH3Dfuture149.sh3d
08/10/2023 01:22 PM 312,102,837 3200SH3Dfuture150.sh3d
08/16/2023 08:39 PM 244,547,641 3200SH3Dfuture151.sh3d
08/18/2023 10:30 AM 244,548,342 3200SH3Dfuture152.sh3d
02/21/2024 05:02 PM 241,391,825 3200SH3Dfuture153.sh3d
02/21/2024 10:47 PM 241,391,873 3200SH3Dfuture154TV.sh3d
02/24/2024 09:21 AM 241,401,991 3200SH3Dfuture155TV.sh3d
07/29/2023 08:04 PM <DIR> Custom
02/24/2024 10:59 AM <DIR> Diagrams
02/24/2024 11:00 AM <DIR> Misc
01/16/2024 11:40 AM <DIR> Models
02/21/2024 11:13 PM <DIR> OldSH3D
02/23/2024 05:34 PM <DIR> Plug-ins
02/21/2024 10:58 PM <DIR> Renders
02/24/2024 10:42 AM <DIR> SH3D Models
08/19/2023 04:49 PM <DIR> SH3D Textures
02/23/2024 05:40 PM 11,384 test.sh3d
02/24/2024 10:42 AM <DIR> Textures
14 File(s) 3,331,827,311 bytes
12 Dir(s) 404,607,152,128 bytes free
Steve, I sent you an email with a special version which may fix your issue, using a [font=courier new]FileDialog[/font] rather than a [font=courier new]JFileChooser[/font] instance in case the error you reported happens.
If it works, I'll commit the change in source code.
As I fear that the Java bug #8305072 takes a long a long time to be fixed (it seems complicated to reproduce), I chose to circumvent it by using a [font=courier new]FileDialog[/font] rather than a [font=courier new]JFileChooser[/font] instance in case this error happens (see commit #8910).
Steve confirmed that it fixed his problem. I'll publish a version 7.3 Beta soon with other small changes.
