If I'm not mistaken, that code is only the transformation part, i.e., move the target object to the coordinate system of the camera, but the projection itself is done as a part of the renderer's internal code as SH3D provides the lens type, FOV, aspect ratio, etc.
I didn't see the perspective projection part in both renderers but maybe I missed it...
Mapping Floor Plan Coordinates to Render/3DView Coordiantes
This topic has been viewed 11722 times and has 12 replies
- Daniels118
- Country: Italy
Re: Mapping Floor Plan Coordinates to Render/3DView Coordiantes
Whops, seems you're right... this tells how to compute the projection matrix:
https://gamedev.stackexchange.com/quest ... -in-opengl
But you don't need to do it by hand, because Java3D has a ready made mathod for this:
https://download.java.net/media/java3d/ ... %20double)
Java3D is embedded in SH3D installation, so you just need to add it to your build path, you don't need to embed it in your plugin.
I finally got it to work, thanks Daniele!
For future reference, if anyone will stumble upon this post, here's what I ended up with:
int renderWidth = 1024;
int renderHeight = 576;
/* Set up */
Camera camera = getHome().getCamera();
cameraPosition = new Vector4d(camera.getX(), camera.getZ(), camera.getY(), 0);
Transform3D yawRotation = new Transform3D();
yawRotation.rotY(camera.getYaw());
Transform3D pitchRotation = new Transform3D();
pitchRotation.rotX(-camera.getPitch());
Transform3D perspectiveTransform = new Transform3D();
perspectiveTransform.perspective(camera.getFieldOfView(), (double)renderWidth / renderHeight, 0.1, 100);
perspectiveTransform.mul(pitchRotation);
perspectiveTransform.mul(yawRotation);
HomePieceOfFurniture furniture = /* Get some furniture... */;
Vector4d objectPosition = new Vector4d(furniture.getX(), furniture.getElevation(), furniture.getY(), 0);
objectPosition.sub(cameraPosition);
perspectiveTransform.transform(objectPosition);
objectPosition.scale(1 / objectPosition.w);
System.out.println(String.format("Projected pixel: (%d, %d)",
(int)((objectPosition.x * 0.5 + 0.5) * renderWidth),
(int)((objectPosition.y * 0.5 + 0.5) * renderHeight)
