Rendering crash
This topic has been viewed 7247 times and has 13 replies
Guido65
Rendering crash
Post by Guido65 »
Hello everyone, I don't know why, but suddenly the file started crashing every time I ask it to create a photo, even with low quality and resolution. The previous file, which was larger in size, didn't give me any problems. This is the link to the file that doesn't work: https://www.mediafire.com/file/ks4mjxs3 ... d.pdf/file . Can you help me? Thank you!
Re: Rendering crash
You're sharing the wrong file... It's called MediaFire - Getting Started.pdf
Guido65
Re: Rendering crash
Post by Guido65 »
Vinci68
Re: Rendering crash
Post by Vinci68 »
Oddly enough, in my case, at maximum quality and 4K resolution, the photo is created without a hitch. So it's not the file that's the problem!
Guido65
Re: Rendering crash
Post by Guido65 »
I really don't know why it doesn't work! Aargh!!
GaudiGalopin3324
Country: Russia
Re: Rendering crash
Post by GaudiGalopin3324 »
hello. A very beautiful project! I found a problematic model here. This is a ping pong table top. If you make the white markup invisible, everything is displayed perfectly. I cured this problem by creating a second copy of the table, but made everything there invisible except the white markup. I combined everything exactly and raised it 1mm higher than the first model. And in the first model of the table, I made the white markings invisible. And everything has been fixed). Photos now turn out perfectly in any quality. Sorry, I added the sky and a large hemisphere.))
1h12m 3000х2250 pixels
the corrected file is here https://www.mediafire.com/file/1fkdw7w4 ... .sh3d/file
GaudiGalopin3324
Country: Russia
Re: Rendering crash
Sorry, it turned out to be even simpler. In the Ping Pong model, you need to make part No. 9 invisible.
Guido65
Re: Rendering crash
Post by Guido65 »
Sorry, but I didn't quite understand if my original file also crashed for you and what changes you suggested to avoid issues. Nonetheless, I tried opening your file, and unfortunately, it still crashed for me. At this point, it must be a problem related to some incompatibility with my PC (which is really strange because it generates other sweethome file renderings, even heavier ones, without any problems...)
GaudiGalopin3324
Country: Russia
Re: Rendering crash
I have your file loaded normally, it does not refuse. But the table is loading with an error, I thought that's what you meant. And I assumed that this error could have caused you to reset the render for some special reasons. But now I understand that there is some other problem here. Yes. The table from your file is loaded like this
if you make AUTO 9 invisible, then like this
but now we must think about the real reason for the failure.. I don't know now.
Re: Rendering crash
What memory usage is indicated in the About dialog box?
What renderer did you try?
