Struggling with 3D views
This topic has been viewed 1288 times and has 2 replies
I seem to have limited facility seeing what I want to see, moving around, etc. Like I want to zoom in on some feature, and I can't get to it at my preferred angle because it disappears off the top of the frame. Am I missing some aspect of controlling these views? Or are there limitations?
DaveLab
Somewhere in western Massachusetts
Re: Struggling with 3D views
I encounter the same when opening a project. What I do is zoom far out and drag one of the larger objects far to the right, left, up, and down. This enlarges the zoom/view area of the 2DView. Ctrl-Z to move the object back to its original place.
If the problem is with the 3Dview instead of the 2Dview: Download the Pan3Dview plugin from SourceForge or use the Plugin Manager .
You can also check your preferences and try to check/uncheck "Aerial view centered on selection".
Wow. Great plugin(s)! A world of difference! Thanks so much!
Yeah, it was 3D view. Although I'm sure your 2D view trick will be useful as well. [:)]
DaveLab
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], MSN [Bot], Semrush [Bot]
