Floor to ceiling columns
This topic has been viewed 1610 times and has 6 replies
Is there a way to make Floor to ceiling columns I've been trying messing with the heights section for walls and no can do so far unless i am not doing it correctly but i believe there is no Floor to ceiling columns feature just yet
Re: Floor to ceiling columns
Also how do i add images like some threads have id like to add my home project for reference
Floor to ceiling columns are simply columns with the same height as the walls. Make sure your level height is the same as your wall height. Make columns with small squares of walls, a cylinder, or a box. You can also create custom columns by stacking other objects or download 3D column models. Just make sure their height is the same as the wall height and they should be floor to ceiling.Is there a way to make Floor to ceiling columns I've been trying messing with the heights section for walls and no can do so far unless i am not doing it correctly but i believe there is no Floor to ceiling columns feature just yet
What do you mean by "add images"? You can set the texture of a side of a box with a screenshot but I don't think that is what you have in mind. Paintings are created that way: a thin box with one side textured with the painting image.Also how do i add images like some threads have id like to add my home project for reference
In this thread adding external images is discussed but that is currently not available in Sweet Home 3D.
i didn't ask about textures i know what a texture is
im asking how do i add a photo of my 3d assets so you can see what i made in the program onto here when someone decides to see my question
as I've seen other threads with their work posted for reference because i don't know how to create an image hyperlink and dont want to learn and shouldn't have to learn just to share my 3d assets with everyone
i think i may have asked the wrong question the wrong way for columns i meant how do i add the header that connects the 2 columns together my apologies
Ah, you mean adding a photo here in the forum. That's easy:
You post the image to an image host like Imgur or Flickr and add the link here in your post. A full link will automatically be displayed as a link but you can also select a word like 'photo' and then click on the 'http' button to add the link.
If you want to share 3D models or a full plan you can use a site like Mediafire or use the Sweet Home 3D models page on Sourceforge .
Users browsing this forum: Bing [Bot], Google [Bot], MSN [Bot]
