Second (sometimes even first) instance of SH is not starting
This topic has been viewed 11090 times and has 14 replies
Gildaniel
Country: Russia
Re: Second (sometimes even first) instance of SH is not starting
Post by Gildaniel »
Nope, there is no eTeks folder neither in users, nor anywhere on ssd.
Vinci68
Post by Vinci68 »
For my part, I had moved the program instances to partition D: when I partitioned my disk:
As a result, I found this folder by following this path :
D:>Documents>My_UserName>AppData>eteks>Sweet Home 3D
Perhaps a clue for you !
Gildaniel
Country: Russia
Post by Gildaniel »
Bingo, thank you!
I have the log in /users/myusername/appdata/roaming/eteks
So, here is the log when I have one file opened and try to open second one (and nothing happens)
https://woodmouse.ru/test/log-nosecondinstance.txt
Daniels118
Country: Italy
Post by Daniels118 »
Hi Gildaniel, this is a known bug of an old version of Pan3dView plugin. Which version are you using? Try to update to a newer one.
See https://www.sweethome3d.com/support/for ... t,80#57000
Gildaniel
Country: Russia
Post by Gildaniel »
Daniels118, thank you very much, I updated the plugin and now everything is ok!
