automatically open .sh3d file on a Mac
This topic has been viewed 17011 times and has 27 replies
buzzz
Country: FR
Post by buzzz »
Hi all,
When I double click on the .sh3D file on my mac, I would like that the file is automatically loaded into SW.
What is the correct approach ?
I see that in build.xml, there is a build option for:
ponderis3D-version-macosx-10.4-10.9.dmg
If I use this dmg installation, does it automatically configure the app and the association between .sh3D files and the app ?
Thx for help
buzzz
Country: FR
Re: automatically open .sh3d file on a Mac
Post by buzzz »
Lol... I just notice that the file name was incorrect :)
We can call that a "lapsus revelateur" :D
The associations between an application bundle and the files extensions is indicated in the [font=courier new]UTExportedTypeDeclarations[/font] section of its [font=courier new]Info.plist[/font] file.
Look at the one of Sweet Home 3D,, it's self-explanatory.
buzzz
Country: FR
Post by buzzz »
I have to test this on my Mac.
can you tell me what version of java (I assume openjdk) needs to be installed for everything to work properly?
buzzz
Country: FR
Post by buzzz »
Hi all,
I have to test the .app build these next days. Currently I have a mac with Ventura 13.6. Which version of java do you use for that ?
Thx for help
On macOS, Sweet Home 3D is bundled with Zulu 15.0.10 as indicated in its Ant project file.
buzzz
Country: FR
Post by buzzz »
Thks Emmmanuel
Do I need to make an app build for each MacOS version ? 12 13 14 ?
I already notice that I have to build an intel plus arm version...
Bundling Zulu 15.0.10 with Sweet Home 3D makes it able to run on macOS from 10.9 to 14.
buzzz
Country: FR
Post by buzzz »
Hi
On my PC with Oracle Java 15.0.2, when I build the officiel SW7.1 source, I obtain the following messages:
[echo] compiling Sweet Home 3D for Java 1.7 minimum version
[mkdir] Created dir: Desktop\SweetHome3D-7.1-src\build\classes
[javac] Desktop\SweetHome3D-7.1-src\build.xml:68: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 2 source files to Desktop\SweetHome3D-7.1-src\build\classes
[javac] warning: [options] bootstrap class path not set in conjunction with -source 7
[javac] warning: [options] source value 7 is obsolete and will be removed in a future release
[javac] warning: [options] target value 7 is obsolete and will be removed in a future release
But, on my mac (13.6), using Zulu 15.0.10 (Zulu 15.46), I obtain two errors:
[javac] error: source option 7 is no longer supported, Use 8 or later
[javac] error: Target option 7 is no longer supported, Use 8 or later
Any idea ?
buzzz
Country: FR
Post by buzzz »
Finally I force compilation with source="1.8", lots of warning, but it works
