It seems there no option to recompute an already created room to make it automatically fit the walls and the doors.
So I suggest to add it as a feature, because when I modify the walls around a room, I have to recreate the room and select again the same texture for the floor, or I have to modify the room manually, that is tedious because of the doors.
Recomputing rooms.
This topic has been viewed 7928 times and has 3 replies
Re: Recomputing rooms.
I've had this idea in mind for a long time, but fear that some special cases could be tricky to program or give wrong results. Maybe I should propose it only in the contextual menu of the plan, and use the point where the right click happened to help.
Nevertheless, note that you could already cut the room you want to adjust, create it again then select the menu item Edit > Paste style to get the color/texture you set previously.
bertrand125
Thanks for the tip.
About using the contextual menu and point where the right click happened, I think it is a good idea and an easy way to use this feature.
You can now use the Recalculate room points item which was added to plan contextual menu in version 7.2.
You have to select a room and right click at a point where the room points should be recalculated to get this menu item. If the points don't need to be recalculated, the menu item won't appear.
