2D view is very slow / lagging up to 1s
This topic has been viewed 20462 times and has 13 replies
Dimitris456
Re: 2D view is very slow / lagging up to 1s
Post by Dimitris456 »
I have the same problem
3D view is very good but 2D and visitor views are slow
I found that if in preferences disable the grid option there is a very big improvement.
vl4d
Post by vl4d »
Yes, monochrome trick helps, but it is still not smooth, i wanted to try online version, but my file is much larger then 20MB :(
vl4d
Post by vl4d »
I have deleted some stuff and got my file from 32MB to about 3.5MB, uploaded to new online version and it is much smoother then grayscale.
Setting 2d view to grayscale helps a lot, but it is still not smooth.
muppetto
Post by muppetto »
I have the same problem. The 2d interface is unusably laggy. I run on popos with flatpak, jar and tar.gz variant of SweetHome3d (ver 7.1).
I noticed whenever I start maneuvering anything on the screen, the cpu usage of the java process goes to 10% and the xorg goes to 35%. I run on an 4 core intel laptop.
