Video format data
This topic has been viewed 8054 times and has 5 replies
enkonyito
Video format data
Post by enkonyito »
Following this , I wanted to test the addition of the Speed and Frame rate fields in the video panel.
I kept the original VideoFormat constructor by replacing the predefined frameRate.
new VideoFormat(VideoFormat.JPEG, new Dimension(Width, Height), Format.NOT_SPECIFIED, Format.byteArray, Format.NOT_SPECIFIED)
I modified the getVideoFormat method for which the videoFormat.getFrameRate() value is not taken into account because it is directly retrieved from the new Frame rate field.
When I play a video, the change in frame rate is perceptible but the value of the recorded data is set at 15 frames/sec.
video test_SH3D-6.0beta_320x240 pixels - 4-3 - 25 frames-seconde.mov
video test_SH3D-6.0beta_320x240 pixels - 4-3 - 50 frames-seconde.mov
EnkoNyito
svedel77
Country: +45 Denmark
Re: Video format data
Post by svedel77 »
If this is getting to work, I'll be so happy!
Matthenry3
Country: Bangladesh
Post by Matthenry3 »
Looks good. Hope this will work perfectly.
enkonyito
Post by enkonyito »
By creating a new instance,
videoFormat = new VideoFormat(VideoFormat.JPEG, new Dimension(videoFormat.getSize().width, videoFormat.getSize().height), Format.NOT_SPECIFIED, Format.byteArray, controllerFrameRate)
the frame rate is updated with each change and the correct value appears in the recorded video data.
userGuideExample_SH3D-6.0beta_speed 0.5x_frame rate 60_PVR-1.6betaTest
Regarding the Speed field, the value is expressed in factor as for most video players/editors. Normal speed (1.0x) is the default speed of SH3D.
Its value change is taken into account when the play/pause button is pressed.
EnkoNyito
Post by bdfd »
Did you test this path in quality 3 or 4 ?
If yes, what was the calculation time ?
pabloab
Post by pabloab »
I tweak the old .mov to be upscaled, slower, and in h264 .mp4, WhatsApp shareable.
#!/usr/bin/env bash
for file in *.mov; do
  scale_factor="2"
  slow_factor="4"
  ffmpeg -y \
    -i "${file}" \
    -c copy \
    -an \
    -vf scale=iw*${scale_factor}:ih*${scale_factor} \
    -filter:v "setpts=${slow_factor}*PTS" \
    -c:v libx264 -profile:v baseline -level 3.0 -pix_fmt yuv420p \
    "${file%.*}_h264.mp4"
    # -stream_loop 3 \
done
