Good morning.
I recently changed computers and installed the latest version of SH3d.
16ram
NVidia GForce gtx 1650 4gb graphics card
The program works fine, no error messages.
The render creates them correctly even in high definition and quickly.
But when I try to add texture to the floors, the problems arise.
The texture is not seen in the 2d screen, however it can be seen perfectly in the 3d screen
Then when I create the PDF of the 2d plan the texture does not appear but it is all white.
I tried using both internal and external textures of the program. But it doesn't work either way.
I thought it was a PDF reader problem but it's not.
I have installed previous versions of SH3d but nothing.
Do I need to install any additional programs or change any settings?
Thanks for your help
Problem with PDF and texture
This topic has been viewed 6165 times and has 4 replies
Re: Problem with PDF and texture
Sounds like you need to change the option "Room rendering in plan:" setting in the Preferences from "Monochrome" to "Floor color or texture"
Thanks, where do I find this option to change?
You could, of course, read the manual... But if that's not your thing, look in "Preferences".
Thank you! I solved the problem thanks to your suggestion!
