I cannot open a file anymore. I've no error when I open it, but nothing shows up. If I tries to re-open it, I've an error that the file is already open.
Can somebody help me ? I can send you the file if it helps.
A weird behavior. If I open SH3D by double clicking on a sh3d file, the process goes under the app group in task manager and the application show up. If I do the same with my other file (the one I cannot open) the process is launched, but it stay on Background Processes, and the app doesn't show in windows.
I'm using 7.0.2 version (was 7.0.0 last time a save this damn file)
File opening but not showing on screen
This topic has been viewed 2809 times and has 6 replies
Re: File opening but not showing on screen
[url=mailto:[email protected]]Send me[/url] your file, I'll try to fix it.
I just tried the file you sent and didn't have any problem to open it and view it under Windows and macOS. Maybe it's an access right not granted to the file in the operating system.
What operating system do you use?
I'm on windows 10. Maybe it is an issue with some plug-in. I'll try to remove all plug-ins and see what happens. Is there some way to launch SH3D in verbose mode to generate some logs ?
ok, i'm able to open it if I remove all the plug-ins. I'll try to reinstall the plug-ins one by one and see which one fails.
seems to be the wiring plug-in that fails....
thank you for you help
- Daniels118
- Country: Italy
If you can share the file I will try to find the bug affecting the Wirings plugin.
