confused Unable to render
This topic has been viewed 2535 times and has 3 replies
crackwood01
Country: Canada
Unable to render
Post by crackwood01 »
i can't render my project.
I don't know if it is a particuler object thats create a bug.
I've always been able to use yafaray or another motor.
Nohing happens at all, just a grey screen.
http://www.crflix.ca/docs/Projection.sh3d
Merci!!
Re: Unable to render
I just tried your file and had no problem.
Did you succeed to render that particular project? Did you relaunch Sweet Home 3D?
crackwood01
Country: Canada
i can render other projects but not this one
Daniels118
Country: Italy
Post by Daniels118 »
You have a 3D dimension line hidden behind the shower. Please note that the versions of 3D dimension lines plugin prior to 3.1 break the rendering (if a 3D dimension line is in the scene). Please check if you have the latest version of the plugin. I recommend to use the Plugin manager with "check for updates" option enabled to keep all plugins updated.
