Lean-to conservatory
This topic has been viewed 5820 times and has 16 replies
Has anyone done a LEAN-TO CONSERVATORY ?
Full length glass walls and a sloping plastic panel roof
Re: Lean-to conservatory
The one that I need is https://3dwarehouse.sketchup.com/model/ ... nservatory and is not available in any Sweet homes compatible format
Any suggestions ?
Any suggestions ?
Neither are any of the others on the same site !
I could easily download and import the conservatory you mentioned in .dae... It is compatible format.
A whipped together a simple example from which you can expand to the conservatory you want. All basic sweethome3d parts with only the roof "window" exported and imported to allow inclining.
https://sourceforge.net/p/sweethome3d/d-models/667/
Nice and useful! Thank you Keet!!
Thank you - very useful
The conservatory appears to be fine in the plan view - but the 3d view is different
The sides are solid (no glass) and the roof is flat !
Euh, not for me... What version of Sweet Home 3D do you use?
