can you change the appearance of the Dimension lines?
eg make it dashed or dots?
this would help make Dimensions much clearer visually and not confused with other plan solid lines
obviously, should be a selection option in Dimension Preferences
Dimensions - Appearance
This topic has been viewed 2587 times and has 7 replies
Re: Dimensions - Appearance
Dimension lines appearance can't be changed.
noted. thank you.
hopefully i am giving you ideas for enhancements?
I had the idea to allow a different color for dimension lines, not sure it will also allow the change you hoped.
yet you already have this function in (somewhere that i cannot remember where i see)I had the idea to allow a different color for dimension lines, not sure it will also allow the change you hoped.
You won’t find this idea anywhere since I didn’t program it yet!
You probably saw it with the polylines, those you can change.
that's it!!You probably saw it with the polylines, those you can change.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot]
