Overlaid Rooms
This topic has been viewed 4269 times and has 4 replies
decard
Country: AU
Overlaid Rooms
Post by decard »
i mention that i can find no information in User Manual
simple question: how is the display order of the (floor) surface of different 'Rooms' determined when they overlap each other?
Re: Overlaid Rooms
Rooms are drawn in the order they were added.
Note that it doesn't give the same result in the plan and in the 3D view.
In the plan, a room is filled with a half transparent color or texture so you'll see other rooms below it (in the levels at the same elevation if any).
In the 3D view, a room floor will cut room floors below it.
decard
Country: AU
Re: Overlaid Rooms
Post by decard »
hmmm. noted.
*** latest on top? any wy to reorder (other than deleting and redoing)? can different Levels be used?
*** 'below' meaning 'added after/later'?
cheers
don
Re: Overlaid Rooms
Lastest added on top (but with transparency in the plan).
To reorder a room you have to cut-paste it.
Only rooms in the levels at the same elevation are drawn (and it depends on which level you selected).
No, it means "added before".
decard
Country: AU
Re: Overlaid Rooms
Post by decard »
sorry. i mis-wrote.
