Volume Plugin
This topic has been viewed 9235 times and has 15 replies
k005
Country: TURKEY
Re: Volume Plugin
Post by k005 »
I compiled it again. I copied it to the plugin folder. I ran sweethome3d. But it crashed... when I deleted the volumePlugin I created, it popped up.
I'm making a mistake on a small point, but I haven't found it yet.
Re: Volume Plugin
A JAR file is actually just a ZIP file. Could you list here its content with a ZIP utility?
k005
Country: TURKEY
Re: Volume Plugin
Post by k005 »
I am adding my work that caused the lock by archiving it. The compiled jar file is also included.
https://www.dosya.tc/server38/u4bxxl/Vo ... n.rar.html
Actually, I just need an icon-shaped starter frame that is placed in the tools menu for now and added to the toolbar. like the frame I gave below.
how should i run it from Sweet Home. I will develop it later.
this will be the map to me...
Thank you.
Re: Volume Plugin
Your plug-in is correct but you compiled it with a more recent version of Java.
In the properties of your project, change the Compiler compliance level to 1.8.
k005
Country: TURKEY
Re: Volume Plugin
Post by k005 »
Ok. Thank you very much. Worked.
Can you send a sample project like in my second question?
I can also go through the volumePlugin... but it has menu placement. There is no toolbar!
Re: Volume Plugin
You could use the method [font=courier new]showInputDialog[/font] in JOptionPane class (see tutorial here).
