Hello. In a 3D view, I make the grass on the ground and the sky cloudy. When I compose the photo, the ground looks like grass but the sky just looks solid color. clouds are invisible. how can i fix this. Is it my fault or the program?
note(I use yafaray when taking pictures)
Thank you.
there is a problem in yafaray
This topic has been viewed 28274 times and has 6 replies
- leonidas187
- Country: Türkiye
Re: there is a problem in yafaray
As explained in the included help, in Aerial view mode, a sky image computed according to the hour of the day is used for the rendering of the sky, i.e. the sky texture you selected is not used.
If it’s not your case, you’ll have to share your SH3D file or at least a picture, to help us understand the issue.
- leonidas187
- Country: Türkiye
I emailed both photos. I want you to know that I tried every hour of the day and it still didn't work.
- leonidas187
- Country: Türkiye
by the way, (edit 3b view) i added cloud texture. There is no problem with the grass texture.
Use Virtual visit mode and you’ll get the sky texture in the rendering.
- leonidas187
- Country: Türkiye
thanks i will definitely try this
- leonidas187
- Country: Türkiye
Virtual visit mode solved my problem. Thank you so much.
