Delete Furniture That There Is No Library
This topic has been viewed 3333 times and has 2 replies
kaotiktrendz
So I have decided to merge all the furniture libraries into one, and then delete the libraries from the folder the program uses so that I would have a clean slate. When I open the program, I still show furniture even though there are no libraries loaded. How can I delete these so that I have a completely clean slate to work from? Thanks
Re: Delete Furniture That There Is No Library
You should remove the file Furniture.jar found in a sub folder of the installation folder of Sweet Home 3D. If you want to keep some items from this library, you should know that Furniture Library Editor accepts to open the file Furniture.jar even if its format is a little different from SH3F files.
kaotiktrendz
Thank you very much, that did it! Now my OCD will be happy hahaha
