I'm a new user, so it could be user error.
I am trying to create a new library with obj files, but when I go to import furniture, no files (or folders) appear once I click into Desktop / Downloads / etc.
See image below. Am I missing something?
https://ibb.co/vkqVRNX
Best, Josh
MacBook Pro (16-inch, 2021) Apple M1 Max
FurnitureLibraryEditor (Import not working)
This topic has been viewed 5228 times and has 3 replies
joshuaanstey
- Country: United States
Re: FurnitureLibraryEditor (Import not working)
Maybe something bound to macOS security which sometimes becomes quite a hell to manage.
You could try to drag and drop the files you want to import directly in the Editor window.
joshuaanstey
Thank you. That approach didn't take either. It did respond some when I did it by showing the "Importing furniture.." dialog for a brief second and then disappearing without the full process taking place.
I have JAVA 18 installed, if that helps. Also, I have access to a PC that I can use to fulfill my needs in the short term, so no worries if MAC is the issue.
Cheers!
Cheers!
Don’t use a Java version > 15, and prefer an Azul OpenJDK Java 15 runtime similar to the one used in Sweet Home 3D.
Users browsing this forum: Amazon [Bot], Google [Bot], MSN [Bot]
