Need help - how do I configure yafaray?
This topic has been viewed 2259 times and has 2 replies
hammm3r
Country: USA
Post by hammm3r »
3rd time posting, my posts aren't going through.
I've searched for how to configure yafaray, but I can't find where the settings are. In particular, I'd like multiple bounces on the light rays.
Re: Need help - how do I configure yafaray?
The messages posted in this forum are moderated to avoid spam. It was indicated after you posted you message but you probably missed the note.
There’s no easy way to configure the special settings of YafaRay renderer yet and you should choose the setting you want from the properties listed in YafarayRenderer.properties and set the Java properties at program launch.
If you want change bounces, you’ll have to set the properties [font=courier new]com.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.diffusedBounces[/font] and probably [font=courier new]com.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.lightingMethod[/font],
for example with Java options
-Dcom.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.diffusedBounces=3 -Dcom.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.lightingMethod=pathtracing
Setting these options depends on the operating system you use. Look at the FAQ about increasing memory to pick up the good option.
You're lucky, Enkonyito already added the new YafaRay settings in the new version 1.4 of his AdavancedSettingsPhotoRendering plug-in.
I will be easier to set them with this plug-in than manually editing the properties value.
