Pan tool in 3D and 2D view?
This topic has been viewed 773284 times and has 112 replies
Daniels118
Country: Italy
Re: Pan tool in 3D and 2D view?
Post by Daniels118 »
I'm not sure what causes the problem, I have even tried to swap left and right mouse buttons in Windows settings, but it stil works as expected for me.
Anyway I have modified the code to handle both buttons, please try the attached version and let me know.
Pan3dView-3.2.2.sh3p
Daniels118
Country: Italy
Version 3.3 released!
Changelog:
  • Added SPACE+left mouse button for panning as in plan view
  • Added Czech translation
  • Minor bug fix
Download from sourceforge or using the Plugin Manager.
Known bugs:
The "hide obstacles" feature is broken in Sweet Home 3D 7 beta. I'll try to fix it once SH3D 7 gets out the beta stage.
Is there something I should have not changed in the program? Maybe it can be updated easily to avoid you to change your plug-in and manage different versions of Sweet Home 3D…
Daniels118
Country: Italy
The problem is caused by the addition of the modelFlags parameter to the HomePieceOfFurniture3D.setVisible method, since it's a private method I did expect my code would have break soon or later. Handling both versions should be quite easy anyway.
I could overload setVisible to keep the old signature too, but as it's a private method, the old version of the method will lead to warnings in Eclipse because it will be unused.
Thanks for accepting to fix it on your side [:)]
Daniels118
Country: Italy
Version 3.4
Changelog:
  • Fixed "hide obstacle" feature not working in SH3D 7
Daniels118
Country: Italy
Version 3.5
  • Fixed the camera jumping bug
  • Fixed Dutch translation
Download the new version from SourceForge or using the Plugin Manager.
Daniels118
Country: Italy
Version 3.6
  • Added the ability to change the 2D/3D panes layout
    Use View 3D -> Pan 3D view settings and check Use widescreen layout.
Don't forget that you can always use CTRL+SPACE to cycle the layout between full plan, full 3D and split.
Download from Sourceforge or using the Plugin Manager.
Nice, nice, nice!!!
Daniels118
Country: Italy
Version 3.7
New features:
  • Added the ability to change the 3D view to parallel projection using CTRL+J (this also enable outlines to improve the aspect)
  • Added the ability to align the camera to the selected furniture or wall using CTRL+K (can be pressed multiple times to align to different sides)
View full size
These new features together with the 3D dimension lines plugin will enable SweetHome3D to produce pseudo-technical drawings in the 3rd dimension. I will publish a video tutorial in the next weeks.
You can download the new version from SourceForge or using the Plugin Manager.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot]
