Apologies if this was asked before. I checked all the questions posted since April 2021.
Is there a way of editing the furniture dimensions by just adjusting the values from the home furniture list panel?
When I try to do that the editing window for that single furniture opens. I don't want that. I'd rather enter values in the necessary fields like in a spreadsheet for the sake of bulk and fast editing.
Editing furniture from the list
This topic has been viewed 2080 times and has 4 replies
Re: Editing furniture from the list
No, this can only be done using the Modify Furniture dialogue panel.
Oh... Maybe I should write a feature request for this. I can't be the only one feeling a need for this, can I? Oh well...
Thank you for answering though.
- Daniels118
- Country: Italy
If you need to change the size of several furniture at once, just select them all and open the edit dialog.
If instead you need a fast selective way, you can edit the home.xml file directly with a text editor.
Finally, if you have programming skills, you can write your own plugin to achieve what you need.
Oh wow! How do I manage to keep missing the replies? Thought I had notifications on.
Thank you for the reply. Unfortunately I don't have such programming skills but editing the home.xml file sounds like something I can do. I'll try that now.
Thank you!
Thank you!
