Problem rendering zenithal photo
This topic has been viewed 4058 times and has 3 replies
Obaldius
Post by Obaldius »
When I want to render a 3D picture from above during daytime, a zenithal shot I believe it's called, sun light will flood my appartment. If I set a celing then I cannot see the inner details of my appartment. How can I take a zenithal picture without a ceiling and without sunlight coming into my appartment? thanks in advanced
[img]file:///C:/Users/vende/Desktop/Sweet%20Home%203D/floorplan/fotos/nuevo.png[/img]
Re: Problem rendering zenithal photo
Sorry it’s not possible at daytime.
Obaldius
Post by Obaldius »
lol
Daniels118
Country: Italy
Post by Daniels118 »
You can eventually add a far away flat object with the same shape of your home that will project its shadow exactly above your home.
This is not exactly the same thing as having a real ceiling, but will come very close.
If your home is rectangular you can use a simple box. If the home has a complex shape it would be easier to create a floor on a new level following the underlaying perimeter and then move it in the proper location. This location depends on the latitude set on the compass and the hour of the day. Although it can be calculated using math, I think that a try and error approach works as well.
Here an example:
The same using a ceiling at 75 meters above the ground and shifted toward the sun:
If you use a ceiling you could find very hard to place the camera at the right place, in this case the Pan3dView plugin can help you because it allow to place the camera below the selected level elevation.
