New Bedroom
This topic has been viewed 15681 times and has 17 replies
Re: New Bedroom
I reworked the lights on the advice of SJB007 and the shines I only have the shadows to improve.
Un dessin vaut mieux que mille explications.
Re: New Bedroom
Wow! That looks a lot more realistic. It has darkened the room down quite a bit though. It could use a bit more indirect lighting (bounce light) to give it a bit lighter feel. Or is the overhead light fixture supposed to be on? If so, that would typically be a stronger light than the others.
A small hint on the bedside lights which is personal preference. They usually have two bulbs in them, one each side. This makes the fan of light broader, i.e.
instead of
Last thing. Is the middle section of curtain/net meant to be a plastic sheet? The upper folds have a shine which makes me think of a plastic shower curtain. If it is supposed to be a fabric net, you should remove the shininess.
| O O |
/ | | \Code: Select all
| O |
/|\Re: New Bedroom
Excellent job. Although if I walked in a bedroom to find that indivdual waiting for me... I would do a 180 and start running. That is one creepy looking figure. Unless "Stepford Wives" is your thing...
Re: New Bedroom
Much better. If I squint it could even be Lucy Liu. [B-)]
