sweet hoe 3d will exit now because a fatal error ....
This topic has been viewed 5975 times and has 6 replies
kfir
Post by kfir »
hi
i update to the last version and try to open previous files and getting this message :
"sweet home 3d will exit now ecause a fatal error in the 3d rendering system of your computer. please update the DirectX/OpengL drivers of your computer graphics card"
i didnt make any changes before i update.
does anyone have an answer or solution for this problem?
Daniels118
Country: Italy
Re: sweet hoe 3d will exit now because a fatal error ....
Post by Daniels118 »
Which operating system are you running?
kfir
Post by kfir »
windows 7.
the version before the last was ok so i downgrade to it and still have the same problem
Daniels118
Country: Italy
Does the error happen only when opening a file or even starting the program alone?
Did you try the suggestions in the FAQ?
kfir
Post by kfir »
one more thing:
on the new version,when i build somthing and save the file and try to open it after few minute ther no problam and everything is ok.
only when i try to open an old file it open and showing me the message.
kfir
Post by kfir »
Thank you Emmanuel Puybaret it works
i uninstalled and install again (32bit) and it works.
again, thank you
