Installing Sweet Home 3D JS Online on my server
This topic has been viewed 8982 times and has 17 replies
kingoftailor
Re: Sweet Home 3D JS Online
Post by kingoftailor »
What is the correct html for the new version?
Later this works for me:
<div id="progress">
<div id="progress-bar" style="width: 0%;"></div>
</div>
<div style="width:100%;height:100%;">
<div id="home-pane" style="width:100%;height:600px;position:absolute;top:75px;left:0">
<div id="home-pane-toolbar"></div>
<canvas id="home-3D-view" style="display:none" tabIndex="1"></canvas>
<div id="home-plan" style="background-color: #FFFFFF; color: #000000" tabIndex="2"></div>
<div id="furniture-catalog"></div>
</div>
</div>
kingoftailor
How can I set the drawing canvas to appear (full size) but not the 3d view?
On earlier version this worked:
#home-3D-view {
  display: none
#home-plan {
  height: 100%;
  width: 100%;
The largest problem is that the buttons seems disabled:
The 3. problem is that there are no right mouse context menu (sweethome online vs megveszLAK.hu test page)
The test page html:
        <div id="home-pane-toolbar" style="height:30px"></div>
        <div id="plan-3D-view-splitter" class="pane-splitter horizontal" style="display: block; width:100%"></div>
        <div id="catalog-furniture-pane">
            <div id="furniture-catalog" style="height:100%;width:100%">
                <div id="furniture-catalog-list" class="furniture-catalog-list"></div>
            </div>
        </div>
        <div id="furniture-plan-splitter" class="pane-splitter vertical" style="display: block; left: 330px;"></div>
        <div id="plan-3D-view-pane" style="position:absolute; left: 332px; width: calc(100% - 334px);height: calc(100% - 34px)">
            <div id="home-plan" style="background-color: rgb(255, 255, 255); color: rgb(0, 0, 0); width:100%;height:100%" tabindex="2">
                <canvas id="home-3D-view" tabIndex="1" width="1" height="1" style="width:100%;height:1px"></canvas>
            </div>
        </div>
    </div>
</div>
The JavaScript:
<script>
        var homeName = "emptyHome";
        var urlBase = "https://alaprajz.megveszlak.hu/";
        var application = new SweetHome3DJSApplication(
                readHomeURL: urlBase + "homes/" + homeName + ".sh3d",
                furnitureCatalogURLs: [urlBase + "lib/resources/DefaultFurnitureCatalog.json"],
                furnitureResourcesURLBase: urlBase
        application.getUserPreferences().setNewRoomFloorColor(0xFF9999A0);
        application.getUserPreferences().setAerialViewCenteredOnSelectionEnabled(true);
        application.getHomeRecorder().readHome(homeName,
                homeLoaded: function (home) {
                    home.setName(homeName);
                    application.addHome(home);
                    application.getHomes()[0].setCamera(application.getHomes()[0].getTopCamera());
                    window.addEventListener("unload", function () {
                        application.deleteHome(home);
                homeError: function (err) { },
                progression: function (part, info, percentage) { }
    </script>
Thank You
The CSS and HTML parts in the main page index.jsp changed a lot between versions 6.4 an 6.6, and you should probably add the changes carefully in your page.
kingoftailor
Thanks, I've already done it based on index.jsp.
There are two things I haven't found a solution to. I was unable to resize the drawing surface and the furniture selector jumps too wide from the initial width.
How can I set the width of the furniture selector?
How can I hide/remove the 3d view?
How can I hide/remove the furniture view?
kingoftailor
I resolved to hide 3d view and furniture details view:
#catalog-furniture-splitter {
            display: none;
        #furniture-view {
            display: none;
        #furniture-view .tree-table {
            display: none;
#home-plan {
            width: 100%;
            height: calc(100% - 2px);
            font-family: sans-serif;
            border-top: 1px solid gray;
            border-bottom: 1px solid gray;
        #plan-3D-view-splitter {
            display: none;
        #home-3D-view {
            display: none;
The right click menus work perfectly.
kingoftailor
I figured it out.
The furniture selector width was sette in the sh3d file (initial width).
I created another emptyHome.sh3d with the windows version and the problem is resolved.
Great that you could find out by yourself. Sweet Home 3D JS Online version uses CSS with well named styles for this purpose.
Please share a link to the final version when it's ready.
kingoftailor
Your software is very cool.
Here is the online version:
https://megveszlak.hu/alaprajz-tervezo
