Furniture not importing on MacBook Air M1
This topic has been viewed 5556 times and has 8 replies
wismeijer
Country: The Netherlands
Post by wismeijer »
Hi guys, having trouble importing new furniture on SH3D.
When I download a (Collada) ZIP file from 3D Warehouse, I can load it but when the orientation screen appears SH3D 'hangs' and I have to force quit the app.
Anybody else having this problem?
Version used:
Versie 6.6.1 Mac App Store
OpenJDK versie 15.0.2 - 64bit - ARM - 0,1 / 4 GB geboden door Azul Systems, Inc. Java 3D versie 1.6.1 - JOGL 2.4.0-rc-20210111
Re: Furniture not importing on MacBook Air M1
Try to run the program with Rosetta at least while you import a 3D model. What macOS version do you use?
snortrip
Post by snortrip »
I had a similar problem. So far, unfortunately, I could not find a solution.
My favorite collection of 3D furniture models is here.
snortrip, are you sure you use Sweet Home 3D 6.6.1 like wismeijer?
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
I have the same problem with the current version of SH3D for Linux on Ubuntu 21.10.
Pascal
pharmonie
Country: Germany
Post by pharmonie »
Same here. MacBook Pro 14" 2021 with M1 Pro. It's freezing in the orientation view after selecting in obj file to import. using Sweet Home 3D Version 6.6a.
Did you guys find any workaround yet?
I can confirm, that importing entire libraries is working.
Pharmonie, your case is a little different because you use the free version in which case you should use the special version available at
https://www.sweethome3d.com/downloads/S ... -2.3.2.dmg
As this version can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item.
UbuntuBirdy
As a workaround I import the models with the FLE, save it in a library and then import that library with SH3D.
Works for me with Ubuntu 21.10 and SH3D 6.6. Hope that's a (temporary) solution for the M1 too.
Pascal
snortrip
Post by snortrip »
https://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg
Puybaret, thank you! This solution worked fine in my case.
