How to adjust the transparency of one or several walls only, NOT ALL
This topic has been viewed 2127 times and has 3 replies
Is there a way to adjust wall transparency per wall and not only globally?
- Daniels118
- Country: Italy
Re: How to adjust the transparency of one or several walls only, NOT ALL
Can you explain in detail the purpose of the request?
If you want a wall made of transparent glass there is a special window made of glass blocks, or you can create your own with 3D modelling software like Blender.
If instead you want to hide a wall to better view inside a room you have several options:
- change the wall height to a lower value;
- use transparent boxes to cut out parts of the wall;
- use Pan3dView plugin which has a feature to automatically hide the walls that obstructs the view.
I created a level containing only the gravel layer that's all around the house and on a slope. I made that with walls instead of boxes and triangles. [moderated]
[Note from moderator: don't hope more help if you start to be vulgar]
