Strange Lines on 3D Layout
This topic has been viewed 5992 times and has 9 replies
stef.salmon
Country: UK
Post by stef.salmon »
I have done a simple 3D layout using the YafaRay engine, but I have a few strange lines which look like shadows.
I'm using a solid black for the floor and a solid white for the sky with the time set to 1am.
https://www.dropbox.com/s/83j5nyvv0z4nl ... t.png?dl=0
Any ideas?
Thanks in advance.
Re: Strange Lines on 3D Layout
The lines top left and top right??
Try to uncheck "ceilings" and see if they disappear.
If ceilings are needed, make sure all <!> walls have the same height.
stef.salmon
Country: UK
Hi Hans,
Yes that's what it was.
The outer wall was only 50cm high, that's because the layout is in the middle of the building and I was trying to encapsulate the floor by making the walls smaller and creating a room to shade in with a texture.
If that makes sense?
All the other walls are 250cm high.
Thanks.
stef.salmon
Country: UK
I'm getting a bit fed up with these lines appearing. The time is set to 1am in the morning and I'm still getting shadows.
https://www.dropbox.com/s/w23w0fnhsxvdx ... t.png?dl=0
Any ideas how to stop this?
Thanks in advance.
Hard to say without access to the original file.
Most often these are ceiling parts, caused by ceilings between walls of uneven height.
Uncheck "Ceilings" in all rooms to (try and) solve it.
I think this is due to large rooms. Does it happen with both the default and YafaRay rendering engines?
stef.salmon
Country: UK
Hi Hans,
If I sent you the project file would you be willing to take a look?
Thanks, Stef
Of course
stef.salmon
Country: UK
Hi Hans,
Thank you very much.
https://www.dropbox.com/s/2x215m76w78y0 ... .sh3d?dl=0
Regards, Stef
stef.salmon
Country: UK
Hi Hans,
Do you know where I can get a closed door from, as like you said I think that is what is causing these random shadows?
Thanks.
