Inserting steps and staircase
This topic has been viewed 3010 times and has 5 replies
luigisoft
Post by luigisoft »
Hit,
I have a house with two storeys and I am attempting to enter a staircase to connect the two.
My problem: The objects available do not suit my purpose, that is I can't modify them to fit in to the space between the floors available.
Q1: How can I build a staircase made up of steps which turn approx. 90° two thirds of the way down with a bannister on the left wall going down? The steps are between two walls.
Q2: How can the stair objects available in 3D be adapted to suit the position and the shape of the space available at the ground floor and where the stairs end, at the 1st floor?
I appreciate any pointers.
Thank you.
Trevor.
Re: Inserting steps and staircase
Q2 - You can change the size and colours of staircases, or make parts invisible. You can also flip (mirror) the model. You can't change the model itself, e.g. add extra steps to a staircase.
Q1 - You can build your own model using boxes, triangles, etc. Then export it, import it and mark it as a staircase during importation. Read the User Guide.
luigisoft
Post by luigisoft »
Thank you for your response.
Is there a programme I can use to build my own model or can this be done within sweethome 3D?
TW
PhiLho
Post by PhiLho »
There is Art of Illusion recommended on this site.
Plus a number of free softwares listed in this article: https://all3dp.com/1/free-3d-modeling-s ... re-3d-cad/
I tried a number of them, some doesn't work on my computer (low end Intel graphics card), some are broken (bad registration process), I was a bit successful with Art of Illusion (after deactivating OpenGL), DesignSpark Mechanical (made a primitive cheminey with it), I plan to try Wings 3D.
harbinger
Country: Clearwater, FL, US
Post by harbinger »
I hate the learning curve of most 3D programs, as they have a lot of features (and the accompanying GUI) that i dont use. Blender is the worst of the free ones, but AoI is the easiest. It's still a little hard to get used to, but it has a simple interface (altho no support).
Still, AoI is tried and true and works for the most part at creating complex architectural pieces for your SH3D home. The texturing and material use is hit or miss and takes a lot of trial and error. My advice is add flat pieces -- don't extrude or manipulate primitives, so the textures don't blur or streak when importing to SH3D.
bdom
Post by bdom »
Bonjour:
pour un escalier personnalisé
il y a plusieurs techniques et astuces
commence par t'entrainer un peu sur un plan vierge
1) utiliser des morceaux d'escalier existant
double cliquer dessus
cliquer sur modifier matériaux
sélectionner une partie 'elle clignote'
elle peut être rendue invisible
avec 2 ou 3 tu peut faire de l'à peu près
2) avec des objets 'notamment boite ou des étagères'
en redimensionnant et ajuster l'élévation
création d'escalier simple
3) la fonction grouper
une fois ta marche et contre marche faite
tu sélectionne l'ensemble
clic droit et grouper
cela te fait une marche complète
tu peux utiliser du copier coller et ajuster l'élévation
(note si tu clique sur un groupe attend 2 secondes et de nouveau clic droit tu peux modifier ou supprimer ce seul objet du groupe
pour aller plus loin
des plug-in sur le site Sweet-home sont disponible
3) conception complète les outils disponible
pour avoir de l'aide sur les plug-in en français
pour le MAC il faut ouvrir le site sweet-home avec google chrome
si on utilise safari on a pas la traduction
dans la page faire un clic droit
choisir traduire en français
- le plug-in générer forme 3D
outil/ générer forme 3D
tu peux te créer une marche de ta forme
- avec le plug in multiplier
tu peut multiplier la 1ère marche en la décalant et la relevant
tu sélectionne l'objet ou groupe
menu outil / multiplier
ton nombre de marche
décalage Z = hauteur
décalage x ou Y longueur marche
ensuite tu as mème les rotations mais je n'ai pas utilisé
petite astuce
le groupe de marche créé ne comprend pas la marche qui à été dupliquée
pour simplifier les ajustages
déplacer la marche de base
et descendre l"élévation
cela donnera un escalier d'une pièce
pour modifier 1 marche ou en enlever une (ex: perron )
cliquer sur l"escalier
attendre 2 secondes
cliquer sur la partie à modifier
d'autres plug in permettent de sauvegarder ses propres meubles...
à découvrir
mac mini 2020 plan technique plus que déco
