Glass wall
This topic has been viewed 7692 times and has 6 replies
- LizardQueen
- Country: Spring Valley, California, United States
Glass wall
Is there a way to make a glass wall? I am trying to make a conservatory/greenhouse.
reddy.shyam
Re: Glass wall
Take a glass window object and modify to take make the borders invisible. That should do I believe.
- LizardQueen
Re: Glass wall
Thanks. Will try. Will post again with how it came out.
- LizardQueen
Re: Glass wall
Didn't come out quite right. I put in a wall, then put in the window and made it big enough to take up the whole wall (height & length wise). Looks pretty good.
reddy.shyam
Re: Glass wall
Well done there! As long as things work, all is good.
As far as I am aware, we cannot put a window without a wall. So yes, making window as big as wall, sounds like an idea solution to us newbies.
Let's see if experts have a better solution.
Re: Glass wall
When importing a new model, mark it as Doors/Windows and you can insert in a wall.
In the attached files, you can find several transparent boxes. Combine your preferred colour with normal boxes (or low walls) to construct your own windows. Export, import and mark as Door/Window.
reddy.shyam
Re: Glass wall
Thanks hansmex. Will remember the tip.
