How to raise the ground floor to 10 cm..? like skecthup with pushpul/down
tks
Raise the ground floor
This topic has been viewed 197455 times and has 8 replies
Re: Raise the ground floor
Onder a level at 10 cm elevation and build your house/room there.
but this is on the ground floor, not on the second level, because there is no elevation
It isn't exactly clear what you want. You could add a level at -10 cm and the house would be below the ground...
sorry, I mean how to thicken the floor to 10 cm at level 0
Assuming you don't have any levels yet:
1 - add a second level, this creates two tabs for the levels
2 - select and double click the tab for the lower level
3 - change the floor thickness.
thanks for explanation, very helpful
how to make a hole in the wall..?
