Adding a crawl space afterwards
This topic has been viewed 2229 times and has 2 replies
zuize411
Country: lostanglest
Post by zuize411 »
Hi! Thanks for this great program!
I am trying to add a crawl space after I have designed the other levels (my mistake). So I added a new level with some walls, set elevation to 0 and added the height of the crawl space as elevation value to the other levels (3 levels). All elements, furniture etc. are now correctly elevated but the walls are not elevated. The walls of the ground floor are e.g. still on the ground (and therefore obscuring the crawl space). They should be on top of the crawl space. I have done houses with basements before (negative elevation) but then I have always started with the lowest level. Now I am trying to add it afterwards. What am I doing wrong?
Re: Adding a crawl space afterwards
Several possibilities, hard to say without seeing your design.
Can you share it?
digitaltrails
Country: Wellington, New Zealand, New Zealand
Post by digitaltrails »
Perhaps you could try and create a new model with the right levels and then cut and paste all the content of the old model into the correct levels of the new model.
