I created and imported a trapezoidal window. How do I create wall hatch for it?
This topic has been viewed 2626 times and has 9 replies
titust11
Country: Canada
Post by titust11 »
I don't understand why if I add a window from the SH3D built in
furniture library, I can insert it in a wall and I don't need a hatch, but if I create my own window, I need a hatch.
Guess what... if I have a non conventional (trapezoidal) window, there is no way to find a trapezoidal hatch for it.
I am stuck... please help
Guys I really like this application but it lacks some basic features.
Any idea?
Re: I created and imported a trapezoidal window. How do I create wall hatch for it?
When you import a model that you want to use as for our window, you need to check the box door-window. Read the user guide...
titust11
Country: Canada
Post by titust11 »
Thanks but unfortunately if I do this, is cuts a rectangular hole in the wall. I don't know how to attach a picture to this forum to show you
Be sure that the wall where you placed the window has a null arc extent because Sweet Home 3D isn’t able to compute not rectangular shapes in round walls until now.
Would it be your case?
titust11
Country: Canada
Post by titust11 »
My wall is not round
titust11
Country: Canada
Post by titust11 »
You can see on YT - the window in the wall. It's ugly
https://youtu.be/8b5qNCE_Wq0
Je ne comprends pas pour quoi on ne peut pas trouver une solution a ce probleme
I just checked on my side with a similar hole in a wall and it worked with no problem.
Share you window model, it might be handy to understand your issue.
TrapezeWindow.sh3d
(8.29 KiB) Downloaded 610883 times
titust11
Country: Canada
Post by titust11 »
How do I attach a file in this forum?
titust11
Country: Canada
Post by titust11 »
I have sent you an email with two attachments
The front face of your model is its border which is rectangular. Rotating it 90° in the second step of the Furniture import wizard will fix your issue.
