Bumping this to keep this feature request alive.
With many of my architectural plans, ceilings are lower in different rooms but much lower than the height of the level and so I put in soffits to account for the ceiling space in the shorter rooms. The problem is, since we can't put in a negative elevation, i have to elevate it on the lower level.
When I then preview that level, the ceiling soffit shows up on the lower floor and I can't see the wall layout of that floor. If I could apply a negative elevation to a soffit which is being used to block off a ceiling, I could assign it to the floor above so that the soffit doesn't block the view.
NegativeAllow the elevation of the object to be negative!
This topic has been viewed 27590 times and has 17 replies
crackwood01
- Country: Canada
Re: NegativeAllow the elevation of the object to be negative!
I truly agree!
So much time i've asked myself: why can't the object be negative elevation?????
J'appuie TOTALEMENT cette fonctionalité. Il serait beaucoup plus simple de pouvoir donner une élévation négative que de créer des niveaux inutiles.
Just tried to do this today... would have been nice.
Yes to this! BUMP!
I join the bump! Negative elevation would be a real time saver.
crackwood01
- Country: Canada
It's gonna be a bumpy ride ....
Usefull function, as far as wall elevation
I’m not sure that negative elevations of furniture will happen, but sorry, don’t hope for wall elevation. If levels behave a little like layers, they are not layers.
