I got some Problems to set a Wall (Angles seems to be the problem?)
This topic has been viewed 2499 times and has 4 replies
lozdigloz
Country: Germany
Post by lozdigloz »
Hello, I found your program and wanted to use it to draw my old building, as I have just submitted a building application for a change of use. The building is a bit older and then apparently people built differently than they do today.
The angles that your program specifies for walls don't fit me. I have now tried to enter the whole thing as it emerges from the old architect's plan, but then I cannot set the final wall.
I have attached 2 screenshots to you and hope that you will understand me despite my poor English.
Does anyone know a solution?
Many thanks and best regards from Germany, Tobias
Re: I got some Problems to set a Wall (Angles seems to be the problem?)
Hold the ALT-key and make your last point, or disable Magnetism in Preferences.
lozdigloz
Country: Germany
Post by lozdigloz »
Yeah, thank you [:)] - deactivating magnetism was the key ;) for my problem!
But now i have another question, maybe you can help me also out with this... [:-/]
is it possible to display the door and window widths and heights in the plan? those from the building authority would like to have it in a special way... :/
For example, they want it in this format[:-?]
100
80
You could add text in that format. It's not possible to do it automatically.
lozdigloz
Country: Germany
Post by lozdigloz »
thanks, so easy and I couldn't figure it out ... :D
