d value in .mtl can be edited in sh3d
This topic has been viewed 5974 times and has 7 replies
- AlbertKakiay
- Country: Indonesia
For developer, to add function for editing d value in mtl, from editing furniture material. So can adjust glass transparancy without creating new object file or changes existing .mtl file.
Re: d value in .mtl can be edited in sh3d
If you want to make a color transparent, you can replace its material by a half transparent texture in Materials modification dialog box.
- AlbertKakiay
Hi Puybaret, Thanks for your response,
I dont really understand, can I have example to create half transparent texture?
Is there half transparent texture in Materials????
Import as a texture the half transparent PNG attached to this post and use it in the Material dialog box to replace the material you want tansparent.
- Attachments
- HalfTransparentGrey.png (126 Bytes) Viewed 140373 times
- AlbertKakiay
Thanks, I understand now.
But, what I am asking is to make it easy for user to have transparant object model (g ...in object), from dialogs box (model material editor).
- AlbertKakiay
- AlbertKakiay
this method can be used also for Mirror, and Open hinge.
Without changing obj file. User can interacts with this dialog box easly.
