HELLO:
THE OTHER DAY I CLOSED THE APPLICATION AND WHEN I OPENED IT AGAIN, IT HAS REPLACED ALL THE OBJECTS WITH FRAMES WITH AN "X" AND IN THE 3D VIEW EVERYTHING IS LIKE GEOMETRIC FIGURES. ANYONE KNOWS THE REASON? THANKS A LOT
THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
This topic has been viewed 10040 times and has 3 replies
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
Did you move the design to another directory? Update your computer? Changed the directory structure?
Aside... which OS do you use, which version of SH3D?
Good morning:
I did nothing. I even open another file that I use from the same work and it comes out perfectly. The system is windows 10. It only happens to me in this file. Thanks
Your file might be damaged. Sent it to [url=mailto:[email protected]]me[/url], I'll try to understand the problem and fix it if possible.
