Floor shadow on the ceiling
This topic has been viewed 5130 times and has 2 replies
paolocesari
Post by paolocesari »
after creating a model with some levels, on 3D view I've found the floor shadow on the ceiling.
Here the some examples:
And my levels:
How can I solve the problem?
Thanks to all!
[Note from moderator: fixed links to images, be sure to use "Direct Link" option]
Re: Floor shadow on the ceiling
This must be the ceiling of some rooms. The height of a level is used to compute the elevation of ceilings and you should enter the height of the level, not the altitude of the ceilings.
So I guess the last column of your level modification dialog box should rather display 320.
paolocesari
I'm really stupid, as you say the height of the rooms should be set at 320 cm.
Problem solved, thank you very much!
