High priority Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
This topic has been viewed 19396 times and has 10 replies
mmrak
Post by mmrak »
Since the latest Update of Big Sur Beta Sweet Home 3D crashes on both my MacBook and on my iMac. I have tested both versions, 6.4.2 (from SourceForge) and 6.4.3 (just purchased from the App Store), both crash at startup, please see attached crashlog.
I was able to use Sweet Home 3D without issues since Beta 4 of Big Sur.
Any hints or workarounds? Uninstalling and reinstalling did not help.
Kind regards
Michael
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
Please report this issue to Apple and check bug ticket #976 for workarounds.
mmrak
Post by mmrak »
Hi Emmanuel,
it did so and sent the bug Reports to Apple. But as I have written above its not the 3D mode that is not working, its the program that crashes at startup. So it might be a different reason.
61Xray
Post by 61Xray »
Hi Emmanuel,
The crashlog gives the following error:
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Don't know if this helps.
Regards,
Michael
mmrak
Post by mmrak »
Hi, is there any progress at this issue? Would be great if this problem could be fixed.
From jkrief report, it looks like the problem is fixed in macOS Beta 11.0.1 20B5012d.
If you’re able to install this Beta version, can you confirm?
lfhring
Country: Colombia
Post by lfhring »
Hi friends:
I want to confirm, the program is working well again in 11.0.1 Beta
mmrak
Post by mmrak »
HI, I can also confirm that the program works again :-)
shabadoga
Post by shabadoga »
Hi all,
I'm trying to run version 6.4.2 on MacOS 11 Big Sur but i have no success. An alert says me to contact the developer to know if the app is compatible with this version of MacOS. Does anyone have the same problem?
Wouldn’t it be because Sweet Home 3D isn’t notarized yet (see bug #951)?
