Convert Polyline to Wall
This topic has been viewed 2963 times and has 2 replies
KitchM
Post by KitchM »
Can the user change a polyline into a wall?
Country: UK
Re: Convert Polyline to Wall
Post by Mike53 »
I do not believe, so but you could draw your wall over the polyline
KitchM
Post by KitchM »
Okay. Thanks. I was afraid of that. I'm trying to build a greenhouse that is buried 4 feet into the ground. There are no walls in the ground so I thought the lines would be good enough. The walls above ground are outside that area. I wanted to see a multilevel design, but I couldn't see the below ground part in the 3D view anyway. Maybe it only shows up if the lines are actual walls.
(I'm wondering if I should do everything in one view instead.)
