Yes, this is clear, but why? Why using an older version than possible?Because he use repository version.
Never too old to play with blocks, I guess...
This topic has been viewed 22756 times and has 14 replies
- UbuntuBirdy
- Country: Switzerland
- Contact:
Re: Never too old to play with blocks, I guess...
Pascal
Yep. And because I wrote that the night before I located the .deb for SH3D 6.3...And why not SH3D 6.3???
so I'm now running 6.3
Many thanks. I've read it - it looks awesome - when I've got time, I'll go through it step by step.Read this post . I've write it especially for guys like You.
Well, my old 2-core laptop runs v4.3 fine - just very slow - and I can even view "top view" for Furniture Icons in Plan in that.Your Core2Duo is not a problem BUT if You have a dedicated graphic card You will need some more settings.
After this operation success we could go to next step.
(Only If You want [B-)] ).
However, v6.1.2 and v6.3 has the Furniture Icons in Plan option greyed out and only displays "catalog icons". I've had that problem on both the old 2-core laptop and the "new" 4-core "media machine".
Crazy Kiwi bloke
Debian "buster" 10 64bit
Sweet Home 3D 6.3 64bit
i5 Quad-core 3.1GHz
8GB 1333MHz DDR3 RAM
i5 Quad-core 3.1GHz
It appears you don't want.(Only If You want cool ).
Why?:
1.
I've never mentioned .deb package.I located the .deb for SH3D 6.3... so I'm now running 6.3
For more precision - You have sweethome3d 6.3+dfsg-1
and Maintainer:[email protected] so
Is NOT Puybaret Emmanuel.
2. One of my machine (at work)
And is an Dell Optiplex 780 made in 2007Operating System: Debian GNU/Linux
KDE Plasma Version: 5.17.5
KDE Frameworks Version: 5.62.0
Qt Version: 5.12.5
Kernel Version: 5.5.0-2-amd64
OS Type: 64-bit
Processors: 2 × Intel® Core™2 Duo CPU E8400 @ 3.00GHz
Memory: 3,7 GiB of RAM
It's a little bit slow but is fully functional(SH3D).
And maybe more other functions You've don't discovered yet.Furniture Icons in Plan option greyed out and only displays "catalog icons". I've had that problem on both the old 2-core laptop and the "new" 4-core "media machine".
From my side it took me a few years to understand that.
I've write the tutorial to make others to avoid this.
Until there I'll wait for you.
I dunno, I'm just lazy, I guess [:p]It appears you don't want.(Only If You want cool ).
Why?:
The package versions have always worked well in the past and I'm just used to doing dpkg for anything I want to install.
So: I finally got around to doing what you told me to do and installed SH3D 6.3 via the file from Sourceforge - and it fixed the problem. I now no longer have the option greyed out and I can view "Top View".
Some other time that's not so late at night, I'll carry on through the instructions for the library editors.
Many many thanks for your help.
Crazy Kiwi bloke
i5 Quad-core 3.1GHz
i5 Quad-core 3.1GHz
Great! Now we can talk!
But for this subject please continue to Installation tread.
I'll wait you there. (Only if you need).
