Can I make either a vertical wall or object, apply a .png image of a tree that has transparancy around the tree, then see that in a 3d view and have the transparent areas of the .png image be invisible, the same as a .png behaves as a 2d image ?
Thank you.
Justina
.png image on wall or object with transparancy...
This topic has been viewed 2030 times and has 4 replies
justthewayur
- Country: USA
Re: .png image on wall or object with transparancy...
You may do that on the side of a thin box found in Miscellaneous category, but not on walls.
justthewayur
- Country: USA
Thank you.
May I ask for a tip please on how to plan the correct size of the image and dpi if I wish a real life size of 5 feet tall by 4 feet wide, and maintain the aspect ratio of the image on the box without stretching.
Cheers.
Cheers.
It's explained in this tip.
justthewayur
- Country: USA
Thank you.
[Solved]
[Solved]
