Export to HTML5 plug-in
This topic has been viewed 5092210 times and has 152 replies
medconsulting
- Country: Switzerland
Re: Export to HTML5 plug-in
Clicking on the Menu item in Tools in SH3D v6.2.1 (bought in Apple App Store) on MacOS 10.14.6 crashes SH3D:
Process: SweetHome3D [35633]
Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Identifier: com.eteks.sweethome3d.SweetHome3D
Version: 6.2.1 (6210)
App Item ID: 669289700
App External ID: 831966744
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: SweetHome3D [35633]
User ID: 501
Date/Time: 2019-11-21 17:18:25.155 +0100
OS Version: Mac OS X 10.14.6 (18G1012)
Report Version: 12
Bridge OS Version: 4.1 (17P1081)
Anonymous UUID: 146C2222-06A5-F9DA-9F2D-0408363A6D61
Time Awake Since Boot: 22000 seconds
System Integrity Protection: enabled
Crashed Thread: 24 Dispatch queue: com.apple.root.default-qos
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000140
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x140:
__TEXT 000000010e603000-000000010e604000 [ 4K] r-x/rwx SM=COW /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Application Specific Information:
abort() called
Thread 0:: AppKit Thread Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff5cc6c22a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff5cc6c76c mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff30bb099e __CFRunLoopServiceMachPort + 328
3 com.apple.CoreFoundation 0x00007fff30baff0c __CFRunLoopRun + 1612
4 com.apple.CoreFoundation 0x00007fff30baf66e CFRunLoopRunSpecific + 455
5 com.apple.ViewBridge 0x00007fff586936c1 __invokeRunLoopInModeForDuration_block_invoke_2 + 25
6 com.apple.ViewBridge 0x00007fff5869361b invokeRunLoopInModeForDuration + 504
7 com.apple.ViewBridge 0x00007fff586933f1 __29-[NSCFRunLoopSemaphore wait:]_block_invoke_2 + 127
8 com.apple.ViewBridge 0x00007fff58693318 __29-[NSCFRunLoopSemaphore wait:]_block_invoke + 308
9 com.apple.ViewBridge 0x00007fff58692ee2 +[NSCFRunLoopSemaphore _observe:whilePerforming:] + 606
10 com.apple.ViewBridge 0x00007fff586929fd -[NSCFRunLoopSemaphore wait:] + 437
11 com.apple.ViewBridge 0x00007fff586920d1 -[NSCFRunLoopSemaphore wait] + 38
12 com.apple.AppKit 0x00007fff2ebddd91 -[NSVBSavePanel advanceToRunPhaseIfNeededLayerCentric] + 334
13 com.apple.AppKit 0x00007fff2e4f77ea -[NSVBSavePanel runModal] + 70
14 com.apple.AppKit 0x00007fff2e4f766f -[NSVBSavePanel runModalForDirectory:file:types:] + 168
15 libawt_lwawt.dylib 0x0000000113d46044 -[CFileDialog safeSaveOrLoad] + 391
16 com.apple.Foundation 0x00007fff32ea9302 __NSThreadPerformPerform + 328
17 com.apple.CoreFoundation 0x00007fff30bcce33 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
18 com.apple.CoreFoundation 0x00007fff30bccdd9 __CFRunLoopDoSource0 + 108
19 com.apple.CoreFoundation 0x00007fff30bb079b __CFRunLoopDoSources0 + 195
20 com.apple.CoreFoundation 0x00007fff30bafd65 __CFRunLoopRun + 1189
21 com.apple.CoreFoundation 0x00007fff30baf66e CFRunLoopRunSpecific + 455
22 com.apple.HIToolbox 0x00007fff2fe0e1ab RunCurrentEventLoopInMode + 292
23 com.apple.HIToolbox 0x00007fff2fe0dee5 ReceiveNextEventCommon + 603
24 com.apple.HIToolbox 0x00007fff2fe0dc76 _BlockUntilNextEventMatchingListInModeWithFilter + 64
25 com.apple.AppKit 0x00007fff2e1a677d _DPSNextEvent + 1135
26 com.apple.AppKit 0x00007fff2e1a546b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361
27 libosxapp.dylib 0x0000000113df1328 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 124
28 com.apple.AppKit 0x00007fff2e19f588 -[NSApplication run] + 699
29 libosxapp.dylib 0x0000000113df0f72 +[NSApplicationAWT runAWTLoopWithApp:] + 156
30 libawt_lwawt.dylib 0x0000000113d750bf -[AWTStarter starter:] + 905
31 com.apple.Foundation 0x00007fff32ea9302 __NSThreadPerformPerform + 328
32 com.apple.CoreFoundation 0x00007fff30bcce33 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
33 com.apple.CoreFoundation 0x00007fff30bccdd9 __CFRunLoopDoSource0 + 108
34 com.apple.CoreFoundation 0x00007fff30bb079b __CFRunLoopDoSources0 + 195
35 com.apple.CoreFoundation 0x00007fff30bafd65 __CFRunLoopRun + 1189
36 com.apple.CoreFoundation 0x00007fff30baf66e CFRunLoopRunSpecific + 455
37 libjli.dylib 0x000000010e6ce8fe CreateExecutionEnvironment + 871
38 libjli.dylib 0x000000010e6ca4cc JLI_Launch + 1952
39 libpackager.dylib 0x000000010e68e4c7 JavaLibrary::JavaVMCreate(unsigned long, char**) + 183
40 libpackager.dylib 0x000000010e68bdb1 JavaVirtualMachine::StartJVM() + 3457
41 libpackager.dylib 0x000000010e68af60 RunVM() + 16
42 libpackager.dylib 0x000000010e69881f start_launcher + 1791
43 com.eteks.sweethome3d.SweetHome3D 0x000000010e603cd9 main + 217
44 com.eteks.sweethome3d.SweetHome3D 0x000000010e603bf4 start + 52
User ID: 501
Report Version: 12
abort() called
Sorry for this issue that seems to happen only with the Mac App Store version.
In case you didn't know, you could also use Sweet Home 3D JS Viewer directly with your SH3D file (save and compress it to get a smaller file if needed).
I try to put in a wordpress page but I don't know how to do it. In my computer works, I upload to the server and appear page not found, I try to put like html code in a wordpress page and don´t work look like uploading all the time. Do you know what I can do?
Can the HTML5 viewer be compatible with equirectangular images ?
EnkoNyito
Do you mean that you wonder if the 3D viewer would be able to generate such images or view existing images (like the sky texture but also with the other half on ground side)?
Yes I wonder if the online 3D viewer would be able to show the panorama from the images created in Sweet Home 3D (spherical lens).Do you mean that you wonder if the 3D viewer would be able to generate such images or view existing images (like the sky texture but also with the other half on ground side)?
If there is a solution to see these panoramas directly in the 3D view of Sweet Home 3D with a fully spherical sky, why not?
EnkoNyito
kelleychambers
- Country: United States
- Contact:
Is anyone having crashing issues? I'm using the Mac App Store version with the highly out of date plugin which I think is causing the crash. Every single time that I export to HTML, the freaking app crashes. Rebooting doesn't help. Renaming the file and opening doesn't do anything. I've GOT to get this exported for my shed builder for a custom quote. Any one know what I could do to keep this bloody thing from crashing? Crash report here: https://pastebin.com/bvYpLvWw
6 posts above in this thread, medconsulting had the same problem and I gave a solution.
This must be due to sandbox restrictions in Mac App Store applications. I recently saw the same issue in the YafaRay plug-in where I programmed a different way to save a file. It should also work for the Export to HTML5 plug-in. I'll post an update soon.
Is there a way to force the "virtual Visit" as the default view (as opposed to the aerial view) ? Sorry if the information is already somewhere, i couldn't find anything.
Thanks for your help and big thanks to the creator of this plugin.
rrraf
rrraf
kelleychambers
- Contact:
Thank you for the reply and while that may be A SOLUTION it's not THE SOLUTION. I'm having the exact same issue for both versions; the MAS and the Open Source version. Now, I'm getting THIS bloody error and I'm about to pull my hair out. I need to get this plan to the construction crew!!!!
PS - And before y'all go blasting me about this being open source software and freely downloadable and I shouldn't get irritated, well, I donate regularly and have purchased the MAS version in an effort to help the project and I really need this software to work as expected.
Screenshot: https://www.dropbox.com/s/wb5djj784ipe1 ... 4.png?dl=0
