Graphic issue - any hints?
This topic has been viewed 10286 times and has 10 replies
I see this graphic issue (rendering with best quality). What can I do to avoid this? Or it's an issue with the model?
Re: Graphic issue - any hints?
Had the same problem some years ago.
My solution:
Import to Verto Studio 3d ( free program) and export obj. file.
Problem solved.
You can probably do the same with Blender, also free.
cec
_________________________________________________________________
EDIT:
If you are working on a Mac or iPad, Verto Studio is still free.
The Windows version is no longer free. Sorry.
Thank you Hans
CEC
My solution:
Problem solved.
cec
EDIT:
Thank you Hans
CEC
Make material on back faces of your model invisible.
Verto Studio 3D now costs €16.79
That is the VR-version ( which is incredible!).
The standard version is still free.
Works sometimes.
See if you can make it work on this: Hummer-no-black.zip
cec
Dear Cecilia,
Believe me, I don't doubt what you say or write. Before writing my answer I searched for "free version" but without result. I would be very interested if you could provide a link to the free version. If you search my posts, this same issue has caused me problems for many years.
Thanks in advance.
Thanks in advance.
https://vertostudio.com/desktop.php
This link takes you to the download page. For Mac it points to Appstore, where the app is free, for Windows( Linux/others, I don't know, since the website obviously sees what platform is making the request, and leads me to Appstore.
Hi Cecilia,
I found that page as well. Unfortunately Apple-only.
Thanks anyhow.
Thanks anyhow.
Hm...
It seems you're right. The standard version is no longer available for Windows.
The tip with making surface invisble doesn't worked.
Blender is an idea, I will test it in the next few days. Thanks.
