I have a drawing where 3d works normal as expected,
made a copy, made some modifications to the copy and
can't get any 3d in the copy. I have moved the camera
to a different room in the copy, however even if put the camera
back in the same place as it was in the original I still
get no 3d in the copy
not sure what I should change in virtual visitor if anything
no 3d in copy of drawing
This topic has been viewed 3684 times and has 4 replies
Re: no 3d in copy of drawing
Did you check the coordinates of the virtual visitor with the visitor modification pane, after a double click on it? And does the 3D view work correctly in Aerial view mode?
ok, after closing doc and reopen it works, but don't know where are coordinates of virtual visitor? and don't know what is the visitor modification pane? I will check documentation and post back
Hi bbxrider,
3D View > Modify virtual visitor
Have a good day.
Have a good day.
thanks veroniQ, looks like you would some severe numbers in there to mess up the virtual viewer, like eyes elevation of like 40'
