Bi-fold doors
This topic has been viewed 8139 times and has 10 replies
Bi-fold doors
Hi
I am a very novice user and I am trying to modify a set of bi-fold doors created by PencilArt, which are in the latest Contributions.shf
Currently, these doors have small panes in them and I would like them to be single panes of glass.
Eventually, I'd also like to have a 3 door version but that's less important.
How do I go about this? I have the Furniture Library Editor but I cannot see how to remove the panes...
Thanks in advance
Thanks in advance
Re: Bi-fold doors
To modify a model you need 3D-modelling software.
The Library Editor is suited only to make libraries, not to do 3D-modelling.
Bubblobill
- Country: Australia
Re: Bi-fold doors
I need something to do. I'll knock one up for you.
Bubblobill
Re: Bi-fold doors
See if this fits the bill
I tried putting it into a library file which might work.
AccordionFoldGlassDoors.sh3f
Failing that, you can import the Object files;
accordionFoldGlassDoors.obj
and
accordionFoldGlassDoors.mtl
Credits to PencilArt and eTeks for prior work.
Regards,
Jay
and
Regards,
Jay
Re: Bi-fold doors
Jay,
Nice try with the folding doors.
Unfortunately, when you insert the doors into a wall, the doors disappear into the wall as well.
Also, could you split the model into more groups, so that more individual parts can get their own colour/texture? Suggestion: doors, handles, bottom rail, 3-sided frame, glass. It would make the model more realistic.
Bubblobill
Re: Bi-fold doors
I just deleted the framing elements that divided the glass panes and added a door handle. Everything else is identical to the original properties. Makes no sense why it wouldn't fit the wall. I must have changed the origin at some point.
As for your other requests.... that will take it from a minor edit to a new model, so maybe.
Probably do it when I get frustrated writing my staircase plugin so chances are good.
Jay
Jay
Bubblobill
Re: Bi-fold doors
Just checked. The origin is the same as the original model.
*shrugs* No idea why it no working
Re: Bi-fold doors
Maybe You could tray this Accordion Folding Doors library.
I've try to make it as Hansmex sugest.
When we will have hinge_on_rail and some glue between parts could be made more complex.
Re: Bi-fold doors
Very Nice!! Thank you.
Re: Bi-fold doors
Just throwing in an observation on the subject of bi-folding doors, I noticed whilst rendering with the doors open that the rendering really slowed down in areas where the rays would be traveling through multiple layers of glass.
I did not see this as a problem more just an interesting observation that ray tracing has a lot more work to do in this scenario, I guess with reflection and refraction going on the number of child rays of parent rays shoots up a fair amount.
