rose Twinmotion 2019 is free!! Recommendation Sweet Home 3D can directly export twinmotion file format
This topic has been viewed 12573 times and has 3 replies
YGYL
Post by YGYL »
Now the OBJ exported by Sweet Home 3D can be imported into TW2019, but the direction is wrong and the glass material should be reset.
It takes a little time to reset.
If it is directly compatible with twinmotion format,
If SweetHome3D is imported into twinmotion and can be rendered directly,
That's a great thing.
The VR function of Twinmotion 2019 is very powerful, and the video rendering is very fast. And it should support ray-tracing rendering in the future. And it's free software.
https://twinmotion.abvent.com/
RockE
Country: AUS
Re: Twinmotion 2019 is free!! Recommendation Sweet Home 3D can directly export twinmotion file format
Post by RockE »
[/url]
So how does one get the exported object to display in Twinmotion correctly? Is it a Sweet Home 3D export issue or a Twinmotion input issue?
I exported my home and it is standing on it's side, using the different axis import options I can get it upside down or below the surface.
Same here
Rolander
Post by Rolander »
Select the whole import (project) on the ride side and use the move and turn function (the triangle that shows up) of Twinmotion to put it in the correct direction plane.
