Not the image i was expecting
This topic has been viewed 4007 times and has 6 replies
Country: UK
Post by Mike53 »
Hi.
I have this image of a recent project,
as images go i am quite pleased with it.....
but.... you may be wondering why it's posted here, well, here is a screenshot taken during the render process
as i said, nice image but not the image i expected..... any ideas as to why this occurred.
Re: Not the image i was expecting
Post by bdfd »
Tell us more, what did you expect ?
The second screenshot is a little blurred so it’s difficult to guess your issue.
Country: UK
Post by Mike53 »
Elevation is totally different, pool is visible in 3d view but does not appear in the image, settings for render are default except silk, same as I always use. 1st image is the render, 2nd image is of the 3d view showing render process.
I'm not sure the rendered image is wrong because it's computed from a higher point of view (look at the roof!). In case you didn't notice yet (but it would be astonishing that it didn't happen to you yet), it's possible to change the point of view and anything else in the scene during the rendering process without bothering rendering engine.
waleedfahmy
Country: Egypt
Post by waleedfahmy »
Try to use virtual visit and change and modify virtual visitor settings elevation of view , field of view to get a satisfying result
Country: UK
Post by Mike53 »
Hi waleedfahmy
Welcome to the forum
Thx for the advise but that was not the issue, the virtual visitor was set up so that the house in the background would be reflected in the pond, foreground, as can be seen in the 2nd image i posted, that image also shows the progress of the renderer, almost finished, the image being rendered does not match, there is no water and the roof is showing, this suggests a much higher elevation. It looks like, as emmanuel said, the viewer elevation was changed, since i don't actually sit here while renders are done, i have my doubts.
